seafox67
Does anyone use an alcohol cooker on their boat in the UK? Where is the cheapest place to get the fuel?
Many thanks
Paul
Many thanks
Paul
I've cooked with alcohol for some years. If you go across the water to la belle France you can get alcool a bruler for not much per 5 litres and that works nicely.
I've cooked with alcohol for some years, using Trangia burners in a gimbled hob. B&Q bioethanol for fuel, not bloody meths. If you go across the water to la belle France you can get alcool a bruler for not much per 5 litres and that works nicely.
I am interested to know how well that works as the Trangia I have for camping just has the meths liquid poured into it, whereas my Origo had wadding in the fuel canister so that the liquid couldn't spill. Also, my T has to be filled every time I want to use it, but the O could be filled and providing the little sealant mat was put back in place, lasted about a week. Do you have to pour the alcohol in while at sea?
After visting a friend's boat where she had an Origo alcohol stove and seeing it demonstrated I decided to get one rather than renew my gas cooker piping etc.Thank you for all your responses... My gas system/pipes is well over due for a service and as I only really use it for boiling water/soups and the Omnia oven, replacing it with a Compass 3000 spirit cooker is sounding a very good option!
it is quite possible to fill a trangia burner at sea. I use a proper fuel bottle so quite controllable. Screwing the lid onto the burner seals it well so no losses between uses. There is a fat o-ring in the lid to do the sealing.I am interested to know how well that works as the Trangia I have for camping just has the meths liquid poured into it, whereas my Origo had wadding in the fuel canister so that the liquid couldn't spill. Also, my T has to be filled every time I want to use it, but the O could be filled and providing the little sealant mat was put back in place, lasted about a week. Do you have to pour the alcohol in while at sea?
Are you using bioethonel?After visting a friend's boat where she had an Origo alcohol stove and seeing it demonstrated I decided to get one rather than renew my gas cooker piping etc.
I have not regretted it and I have cooked quite ambitious meals (for me) on it.
I keep my boat in France and I use this:Are you using bioethonel?
Comparing your Origo with the gas cooker you had before, are you finding the fuel costs similar?
Cheers
Paul
Cheers
Paul
We were bought an Omnia stove for our Origo we have used it on board to heat up part baked bread rolls which were very nice we did a cake in it at home to see how it worked and bruv in law did a pasta bake in it whilst out sailing so it does work.
Omnia Oven UK | The Best Campervan Oven other retailers will be available
