C08
I am thinking of buying a 5hp Yamaha which is air cooled. Is there anything to think about which is different to a normal outboard, apart from no impellers. My interest in air cooled is that it should be lighter than a water cooler but I wonder about the air out vents and whether that make the outboard engine more liable to water ingress onto the electrics and then cutting out? Any views on these engines.
I once had an old Ailsa Craig air cooled outboard engine made by Tomos which was a great engine but even that had a quirk in the you could not run it out of water as the shaft at the bottom was water lubricated and could be damaged by running it dry.
