Advice on size
Not sure what you mean? Scotland is also full of stone buildings and I can’t imagine wooden ones lasting a year!
Timber frame has been the standard for new builds in Scotland for the last fifty years or so. At least in my neck of the woods.
Usually clad in a blockwork rain screen, rendered and painted white. The underlying structure is timber though.
These days timber cladding is become very popular to replace the blockwork.
Actually a timber framed house (in the UK) will typically have greater off site factory prefabrication compared to a more traditional loadbearing masonry (eg. brick and block) house construction.
So the ''stick built'' terminology as described earlier seems to me less appropriate for timber framed and more appropriate for loadbearing masonry construction.
To get pedantic, a stick built house will have minimal prefabrication. Probably just the trusses, which is the same as for brick and block.
Once you start pre-fabbing whole panels, or even move to SIPS, it's no longer what would be called a stick build.
I think that’s why it doesn’t translate to Europe. Here, building with sticks is the far inferior option and usually we use bricks and blocks.
Sure, it doesn't relate well to European construction techniques (other than, to some extent, in the UK).
But it's quite accurate in relation to boat construction.
But it would be very appropriate for timber construction. That's where it comes from. Off site prefab panelized vs. built up on site from "sticks".
Exactly. And that is exactly the analogue to boat construction (y)
