Miura
A friend just had an issue where the fuel line was collapsed. So I would check that the line is in good condition all the way to the engine.
Next there are lots of sensors and they cause issues when either the contacts are dirty or they are faulty
the main one seems to be the temperature sensor. There is also a map sensor. I would find all sensors and put the plug in and off several times and use contact cleaning spray. The sensors are cheap on eBay.
The other one people mention is old fuel. I have suspected this in the past but never had an issue with it.
When was it last running properly ??
The Rib ran fine the day before - thats why I am wondering about the issue. I will try sensor cleaning and plug checking.
When they run its a lot of fun - if not *argh*
