jrudge
The main issue is sensors.Hi everyone I am new to this forum. I’ve read every post and feel you all could be very helpful I am the owner of a 2006 Williams 285 beautifully engineered but has the Weber 750 engine which as we all know it’s getting very hard to maintain due to lack of parts I have a problem where when I try to start the engine it turns fine but just won’t fire and then suddenly it will fire I can warm the engine up turn it off and won’t fire again I have found however if I turn the isolator switch off and on again with the engine warm it fires up straight away did it five times in a row left it for two or three hours tried again and it wouldn’t start but did start after Many attempts compression is fine I’ve got a feeling it’s an electrical issue but could be wrong anyone got any ideas thanks Jonathan
the temp sensor has played up on mine. First check the wiring to the sensors and clean. Next either get it on a diagnostic machine or just change sensors / spark coils until it runs. Not scientific but likely to work.
