jrudge
Strange that the manifold is not available. Have you called Williams directly ?
I was going on what the dealer had told me, but contacted Williams today and they couldn't have been more helpful. They have new and reconditioned units available ....... need to return the old first. Sorry Williams.Strange that the manifold is not available. Have you called Williams directly ?
result!I was going on what the dealer had told me, but contacted Williams today and they couldn't have been more helpful. They have new and reconditioned units available ....... need to return the old first. Sorry Williams.
I cant think of any other reason!result!
so what would be the train of thought behind the "there's no spares" of the dealer? trying to push a new williams and get a bargain on the process or what?
maybe a clearcut case of name and shame then...I cant think of any other reason!
took rib out of water as believed that was an engine out job. Wrong. You can remove with engine in the boat. Catalyst clogged solid with gloop that I suspectwas carbon / salt / salt water overthe years. Removed it. Bashed out the inside. Reinstalled with new gaskets. All back to normal.
so how many ponies have you now gained J?
that's stage one of petrolhead tuning. Next you should go for larger injectors and a remap
on a serious note, how far is the catalyst from the mixing elbow?
V.
tbh, in the crammed space of a jet rib engine room/bay it was silly of me asking how far was cat to mixing elbow...right next to it !
a new catalayst is usd999 ( more in eu I assume ) and ecu sees no faults ( the second lamda is disabled as standard ) so the best thing is it to be gone.
285 min jet £17.500. It’s not mine I just spotted it .What model / price / location
Gulp! I have taken to taking my Williams out of the water every pm if on anchor and also flushing the engine each time.Alas my repair is not so cheap (minijet). Last time out I took it out and once I opened the throttle it went back to idle after 5 seconds. Got it back and noticed water in engine bay. Also noticed a large gash in the hull, which can only be from putting the tender in the tender garage. Initial thought was drive shaft seal, took it back to williams mallorca and they need to remove the engine to repair the gash as needs repairing from both sides. Total cost €3800!
oh well.
Have you contacted the factory. I got one in March and they had a number of new and reconditioned in stock?Hi All, We have the dreaded Manifold failure on a 325 with the 750 engine which Williams are saying is obsolete. Are there any options with this that anyone knows of?
Yes both in UK and Mallorca. Both have said they are unobtainable. I even tried Weber Power in America and they do not have either.Have you contacted the factory. I got one in March and they had a number of new and reconditioned in stock?
