Interesting. I hope someone now puts sling point markers on the gunwhales.
That's a very interesting question!Are these more acceptable to you than outdrives?![]()
Can you put bungee cords on them so they can be recovered ?The drives are designed to shear off if they hit bottom. I could never live with the risk of €40-50k hanging under the boat, but I do most of my boating on inland lakes
I am not an IPS fan but if you shear them off, recovering them is the least of your problems.The drives are designed to shear off if they hit bottom. I could never live with the risk of €40-50k hanging under the boat, but I do most of my boating on inland lakes
A thought...The selling points for IPS are:-
1) Easy joystick manoeverbility.
Get bow and stern thrusters. Much cheaper.
2) Better fuel consumption.
But you will never do enough hours such that the fuel saving pays for the regular gasket and fluid change. It is very expensive oil which is needed, and you need lots of it.
3) Goes faster for the same HP.
With the extra cost you can easily get a bigger engine more than able to make up that difference.
4) You can put the engines further back to make more space for accommodation.
Use a V drive.
Anything else?
Yes, the last time I was at a boat show it was very difficult to find a boat without podsThe selling points for IPS are:-
Use a V drive.
Anything else?
1. I am a good handler, but after a Sea trial a storm with wind gusting thirty plus knots arrived, and it made everything easy, I think I might have failed a bit in this situation if the crew missed catching a rope.The selling points for IPS are:-
Use a V drive.
Anything else?
Some would suggest that IPS has inherited all the old problems of outdrives with couple extra added for good measure.That's a very interesting question!![]()
