Francoisvdm
Hi All, I have a Hurley 22 yacht project which came without any standing rigging. I need some advice on the steel wire diameter to use please. A lot of scratching around the internet seems to suggest that 1x19 316 stainless steel wire of 5mm diameter should be sufficient. Or should I be looking at a 6mm wire diameter? The sail area is approximately 240 ft (22.2 m2), and the ballast 1040 kg. I came across one rule of thumb that the breaking strength of the wire and related fittings should be 2 x ballast which suggests 5mm should do the job.
Many Thanks in advance.
