Poey50
I can't help thinking that life would be easier if you agreed to stay a bit dirtier.
If prices continue to fall like this, surely lead acid will become the expensive option for those who don't wish toIf all is well that is an outstanding deal. Nearly half the cost that I paid this time last year.
Yup. I had been expecting an additional bill but no sign of that.Just to check - is this a delivered price? I.e. including shipping, taxes etc.
A smaller pulley might well do it by running the alternator faster. A couple of questions; is the alternator one of those that are supposedly designed for low speed output and what regulator are you using ?I'm now hungry for more charging Amps rather than stored amps to replenish our consumption so looking into smaller alternator pulleys additional alternators etc to try and get to more Ah of charging
Slightly less than I just paid for 2 T105's delivered. Close to clicking that mouse... best of both worlds ?hm, almost 190Ah useable for 56euro a piece! that's v.good! leaving BMS aside it's Trojan T105 price territory
These ones look OK? Nice price, $436 delivered.
Wholesale Lifepo4 3.2v 230ah Prismatic Rechargeable Battery Cell For Electric Power System - Buy Lifepo4,Lifepo4 Battery,Battery Lifepo4 Product on Alibaba.com
one of the admittedly few advantages of having a 12V boat vs a 24V one. I need 8 of them :-(Checking my invoice, I was $438 for 272Ah nominal. Significantly cheaper than Trojans, which would cost me £690 delivered for a set of four.
What type did you end up buying?Checking my invoice, I was $438 for 272Ah nominal. Significantly cheaper than Trojans, which would cost me £690 delivered for a set of four.
Lishen 272Ah from Shenzhen Basen, on Alibaba.What type did you end up buying?
Is there any import tax involved?Checking my invoice, I was $438 for 272Ah nominal. Significantly cheaper than Trojans, which would cost me £690 delivered for a set of four.
So far, that's all I've paid. It was a DDP price so in theory should include everything. If I get a letter from customs I will update the forum!Is there any import tax involved?
Started the top balance this evening.
Set my Longwei power supply to 3.65v and turned the current up to max. Checked output voltage with my multimeter, all good.
With the four cells in parallel, I hooked it all up and of course the PSU dipped to the cell voltage of 3.31v.
All looked good, drawing about 4A. But after a few minutes the voltage and current both started climbing, and the current began to rapidly shift around the 7-9A region (this is a 10A PSU).
I saw that the voltage had risen to 4v so I disconnected the power and checked the PSU output again on my meter. It was all over the place, with the voltage up at 4.7v at times.
Is my PSU dodgy? Or am I operating it wrongly? I've dialled back the current and it is now sitting stable at 3.3v/0.54A which I think is not going to harm the cells, but will take an age to charge them.
Something is wrong. 4v+ is too high and 3.31v is too low. I’d cross check those readings with a decent multimeter. Maybe test the PSU on a lead battery.Started the top balance this evening.
