spring
I have an MG Spring fitted with a Yanmar 10gm. Flat out I only get 3.5 kt. Other owners get 6kt. The hull is clean - the gear box ratio and prop size has been checked and is correct. the stern bearing is not binding. When flat out I get some smoke and unburnt fuel in the exhaust. The engine has been serviced - injector and timing was checked as was the piston height (bent conrod) Also the exhaust manifold has been checked for blockage but no faults have been found. Otherwise the engine starts and runs very well.
But as I'm moored in Chichester could do with that extra 2 kts.
