How do you know all this?You are better off using bus bars like these that have some flex in them to eliminate that problem
You seem very sure, any links to published papers?
thnx
I'd be surprised considering the amount of copper, the thickness of the bars, that they accept much flex at all. If the cells are not held rigid under, some, compression I'd expect any movement to be absorbed by the cells moving slightly and the nuts slackening. The bus bars illustrated might be useful to absorb expansion from heat - but then they should not get hot.You are better off using bus bars like these that have some flex in them to eliminate that problem
What sort of a response is that if it helps my business imports lithium batteries (for non leisure usage) and I have followed the development of them like a hawk over the past 10 years, which you tend to do when you depend on it for your livelihood.
I'll leave you to it...
I recall that some battery makers, and or their appointed distributers, who supply cells also supply bus bars - but they are simply flat blades of copper. But my memory may be jaded.
However the concept sounds good - so why not? I cannot see any downside (except maybe cost)
I had a quick search EEL BATTERY|Lifepo4 Battery Cells|DIY Battery Pack|Battery Storage System
Jonathan
Many of the applications on your website are for leisure applications.
Not that I understand why the application makes any difference.
But don't be upset to be questioned - its a forum, we are here to learn (or offer advice). There is considerable value in having people with different backgrounds and its also valuable if options and comments have some form of 'peer' review. You would accept questions in your chosen career - why not here.
Jonathan
A thought
If the cells need to be insulated from each other then printers blanket might be a good product. They are thin, around a millimetre in thickness, and are a canvas, or fabric backed, with a 1mm layer of rubber bonded on top. They come in standard sizes to match all the common printing presses. If you know a printer used blankets might do - but will be a bit grotty - the blankets should be available from any retailer/distributor servicing the printing industry (for example Pressroom Consumables. Fast, Reliable Service from Intuprint - I don't know them, just came up on a google search). For the threaded rods used to constrain the collection of cells (or for compression) then the heat shrink tubing used for rope might be ideal. It comes in a variety of sizes and when shrunk thickens up (I buy mine for rope from Aliexpress/Temu etc)
Jonathan
Seems reasonable enough to ask for any test data or published papers for statments on a web forum which say the opposite of the manufacturers (though the language could have been less "in yer face".. )What sort of a response is that
Catl datasheet states cycle life figures are with compression, a quick look at EVE they specify compression used to for testing capacity.
With no evidence to the contrary & no real downside imho seems logical to stick with what the manufacturers datasheets say
fully agree with that, on my boat with a 304Ah@24V lifepo4 bank and 600W solar I charge at typically 0.05C (unless I get generator or engine - v.rare where I go up to 0.25C)The argument is that for cells used in EVs, they are going to be discharged at high C rates so more likely to puff slightly hence the steel case to hold them in shape. In typical leisure applications where they are running at tiny C rates it's far less of an issue.
Again, any test data to back this up?
I think quite a few of us are running close to 1C with large inverters for electric cooking etc- I certainly was with my initial installation, 271Ah battery and 3kva inverter.In typical leisure applications where they are running at tiny C rates it's far less of an issue.
15 years & still full capacity for Rod Collins charging to 13.8V, maybe not....Unless the cells are in an electrical vehicle or similar, they will die of calendar aging way before anything else.
SC, you are right in that the 12V guys do run close to 1C on 300Ah packs while cooking, which granted is the most demanding task (almost even worse than watermaking).I think quite a few of us are running close to 1C with large inverters for electric cooking etc- I certainly was with my initial installation, 271Ah battery and 3kva inverter.
A statistical sample of 1.15 years & still full capacity for Rod Collins charging to 13.8V, maybe not....
I am on 27.7 bulk and 26.4 float on 24v batteries
FWIW, this is mine (304Ah, now into its 3rd year):
two 20mm marine ply on the sides,
cut handles to help in carrying it - still lighter than a 200Ah 12V LA, and similar size...
8cells as it's 24V,
2mm thick rubber sheet between each cell (and cell to ply sides)
4X10mm rods,
two bottom ones closer to each other so that cells rest on them (rods have rubber hose over them so that they wont damage the cells)
busbars with black shrink on them to avoid nasty sorts,
(still not fitted rubber cups on the M6 nuts though)
perspex lid just in case, it's on a locker,
DIYBMS one pcb per cell to communicate state to BMS/passive balance to almost 1A, etc
on the locker above from left to right is power supply to the BMS, BMS (with lcd touch screen, - also wifi/bt), shunt and at the far right bluesea bistable relay,
Class T fuse not in this pic for some reason.
BMS linked to VenusOS raspberry pi which controls/communicates with BMS, MPPT controller (600W on hardtop) and Multiplus 3KVA inverter.
Main load is 1.8kW watermaker and usual crap onboard a 43ft mobo
Re tightening the assembly, I discharged batteries to circa 30% (iirc) and clamped it with a torque wrench at a reasonably low value (which I cannot recall, maybe @gregcope remembers - we discussed them in PMs back then)
Once a year I open the locker to see if they are still there
I do follow their performance via the Victron touch screen on board or remotely from victron VRM:
and or grafana dashboard:
boat currently on the hard, last three days charging is off due to having reached 99% SoC 4days ago and now on rest mode till SoC drops to 35% or so when it will start charging again. I've configured that, need to alter the top charging level but not had the time to deal with it yet. Ideally off season I'd like to have them cycle from 30-50% and just stay there with or without fridge running. I got a more or less permanent 1.3-1.5A @24V load from all the systems on board 24/7 (bms, n2k bus and devices, switch, 4G router, alarm, etc.)
V.
