Chrisgus
Hi Could anyone shed any light on our problem? we have an MD1 that although is 40 yrs old is still running perfectly, however when we start the engine from cold [applying the cold start facility] we get a large amount of soot emitted from the exhaust until the engine revs increase and the cold start is disengaged, as soon as this happens it runs clear and the engine runs cleanly and perfectly all day, with warm starts in between. This soot is emitted with the cooling water and forms a black film on the water. We have recently had the rings replaced and compression is excellant, we have swapped over the injector to our spare and it is still the same. We use standard road diesel, and we are not burning oil. This problem appeared before we replaced the piston rings and we thought by replacing them it would cure the problem. Any suggestions apart from the obvious such as use it as a mooring weight or scrapping, would be appreciated.
Many thanks C
Many thanks C
