Jimham354
Hi there, just taken out our boat for the first actual run since being out for the winter. The engine wasn’t used a lot last year or the year before. The engine temperature warning came on after only a short while of cruising. Water is coming out the exhaust as normal but the strainer never fills up, it is empty to start with and then water is sucked up, but it never fills up even the slightest.
Any advice for what could be the problem and some fault finding?
