roblpm
Well the volatile storage is in RAM and goes when powered down. Did you mean the persistent storage? If so, one of these solutions...
1) No file system - nothing to corrupt. All code is in flash and settings are in a bit of eeprom which are protected by a checksum and maybe a backup copy. If the checksum check fails settings are reinitialised to default or the backup copy is used. YAPPs are like this.
2) Read only file system. It's probably running linux. This can be loaded from a read only file system at boot.
3) Transactional or journaling file system. Big heavy solution. Unlikely to be used in a small device like this.
Yes of course I meant persistent duh!
What i don't quite understand is how any config is then possible? Or maybe it isn't!
