Yanmar YSE12
supermalc
14 Dec 2003
Lincolnshire.
When I got my boat in December last year, I knew nothing about the old Yanmars (didn't even know they existed) however I'll pass on what I have learnt, as it may be a help to others.
The name plate on the clutch housing was missing, making identifying it a real pain.
This is what I have been told, by experienced mechanics, and others have backed this up. It may not be 'gospel' but I think the facts are correct.
The engine was designed as a flat twin in the middle of the 1930s by Coventry Climax.
Yanmar made the engine from half of it making the YSE from 1974 to 77, YSB from 77 to 78 and YSM from 78 to 80.
The manual I downloaded says the YSE is 3 to 1 reduction and the others 2 to 1, but YSEs can be 3 or 2 to 1, so I expect this may apply to them all. Mine is a 2 to 1 reduction, and the engine runs at 3000rpm, so the shaft 1500.
The YSE has a cast iron gearbox, and the front pulley is on a lay shaft, not on the crankshaft.
The YSB has an ally gearbox and the YSM an ally gear box, front pulley on the crank, and a different fuel pump.
I have read, and been told NOT to run the engine slowly for any length of time, as it will quickly wear out. As it is raw water cooled, and 80% of engine wear occurs in the warm up, usually around 10 minutes, this makes a lot of sense. Also, having a heavy piston on it's side, I suspect the oil scavenging will be insufficient to keep the rings from wearing on the bore at the bottom.
I have had to rely on what I have been told, by others supposedly with experience, so if I am mistaken, or anyone can add to this, please do so.
<hr width=100% size=1>Malcolm.
<A target="_blank" HREF=http://www.angelfire.com/rnb/malcsworld/>http://www.angelfire.com/rnb/malcsworld/</A>
Take a look at my boating pages.
johna
12 Aug 2001
Poole
Have a look at the Yanmar Help site <A target="_blank" HREF=http://www.yanmarhelp.com>http://www.yanmarhelp.com</A>
BobL
18 Oct 2001
The YSE12 dates from at least 1972. I had one in my Sabre 27 until a few years ago. The oil pump can be a problem and will let hp oil leak through the rear bearing which is just a steel shaft running in an aluminium housing. It can be solved by boring out and inserting a phosphor bronze bearing. I did mine myself but I recall that Cellar Marine in Cornwall did a conversion package. They are the experts on this engine and it's derivatives which I believe was popular with local fishermen.
