Robin2
My 1GM10 engines are not producing much thrust and the engines do not seem to be reaching full RPM. They are new engines and they used to work fine.
The propellor shafts turn easily by hand so friction in the bearings does not seem to be the cause.
Another possibility is heavily fouled propellors - which I will be investigating.
Does anyone know if the engine will run smoothly but at a lot less than full throttle if the fuel filters are clogged?
I suspect that clogged filters would result in rough running or hard starting - neither of which is a problem.
