hunnsattiller
I would be interested in your legs if you have them still, drop me a line at devonboatworks@gmail.com
Sorry to hijack the thread slightly...
New to me boat (LM 27) came with a pair of pukka beaching legs from when it lived down South. They are adjustable for length and have padded lower hull supports. Is there any special technique for deploying these? Boat lives on the Clyde estuary and it would be nice to be able to dry out on a suitable sandy area to give her bum a scrub!
Thank you for your comprehensive instructions. I just need to find a good drying beach area now. I do know of one excellent spot that I have anchored at a couple of times this season, but it's about a 4 hour sail away from where I am based. I need to go and scope out a couple of the other contenders more locally. First time is going to be a bit nerve wracking...
Wouldn’t a couple of lengths of oak or iroko do in place of all that technology?
Agree with Kelpie to check at low water if possible where you intend to beach but I don't bother anchoring; I simply run aground just after HW and then put the legs on which are both pre set to the keel depth. I think you will find that after about 30 minutes or so the boat will develop a lean in one direction and be resting on one leg only, after which you simply wind the other leg down so it is touching the bottom too. Loads are surprisingly low (in my case about 60% of the weight is the keel) so a slight lean is perfectly acceptable and in my opinion desirable.
I see several of you use them for overwintering.
Are they really OK if you get a gale on the beam? What if Orphelia came your way? is the insurance cover OK?
It's an interesting calculation on the best time to actually go aground. Your thinking seems to be fine but obviously if you need to maximise the time you have available dried out the earlier after HW that you beach the better. In my suggestion (of beaching just after HW) you're aground for nearly 12 hours. I prefer to have time on my side. Whenever you do it make sure you don't get Neaped...now that would be embarrassing!Tidal range is only around 3 metres, so I am tempted to put her aground around 1 hour after high water. She only draws 1 metre, and is long keeled so hopefully that will make finding the right spot a bit easier too...
Just on the point about driving the boat aground rather than anchoring- I've never tried that since my drying spot is a big mud flat at the head of the loch. I suppose if you had a gently sloping beach you could put the boat onto that, but I'd still worry that you're not 100% in control of where she ends up. I think there may be more peace of mind in getting to a spot nice and early and putting out some anchors to make sure you land where you want.
