ean_p
With a small grappling hook and a [Inappropriate content deleted] knife on a long stick....!“Fit a stripper” has moved rapidly up the wish list.
When we found ourselves in a similar situation, although fortunately in calm conditions at 0200, the Lifeboat put their little Y boat over the side with 2 crew armed with an enormous scythe like device. They spent some time trying to cut the line but to no avail. The Cox’n then said he would tow us free, the line parted without a jerk and we were towed in to Harwich.If the conditions are such that the RNLI (reportedly) didn’t want to transfer crew on board, going overboard to try to cut a line round the prop shaft could be suicidal, and presumably with the rope effectively anchoring the boat in a strong wind very unlikely could pull to surface to cut from on board. Presumably the RNLI didn’t feel able to cut the rope safely, otherwise they would have done so and towed the boat to safety.
The point being that a string of pots is unlikely to outperform a Rocna in the yacht immobilisation stakes?The point being....?
Their thinking was that trying to tow the boat with crew on board could result in a pulled prop shaft and therefore a sinking boat, nowhere to safely put it and LB crew who needed rescuing. All in pretty snotty conditions. Apparently in times passed they might have tried but now the emphasis is on saving lives, not property. Rightly so when crews’ lives are at stake.If the conditions are such that the RNLI (reportedly) didn’t want to transfer crew on board, going overboard to try to cut a line round the prop shaft could be suicidal, and presumably with the rope effectively anchoring the boat in a strong wind very unlikely could pull to surface to cut from on board. Presumably the RNLI didn’t feel able to cut the rope safely, otherwise they would have done so and towed the boat to safety.
One at a time with a pot hauler !,And the string of pots is routinely lifted by a boat 20 to 30 feet long.
With respect you sound like a man that has never snagged a pot line. Rocna would be envious of the lateral holding power of a string of 20 or more pots which in the real world are laid alongside wrecks and rock outcrops as a rule ?The point being that a string of pots is unlikely to outperform a Rocna in the yacht immobilisation stakes?
Have to split this up on my elderly iPad.
Anyway, it was obvious we were in for a long night with the breeze forecast to lighten. Still no immediate problem. Another time for patience. Plus I know la Corunna quite well. Plan was straightforward. Sail in to anchorage behind breakwater and at a suitable o clock, call marina for a diver.
Around, I think, 0200 we were doing ok and entering the approaches. I hailed the Harbourmaster on VHF and explained we were ok but limited in where we can Manouver. Twenty minutes or so later, much to our surprise and even more so to its Master, one of their big orange salvage tugs rocked up offering us a tow. What could go wrong? Both the tug skipper and I agreed that my plan was the better option and off he went.
I still had enough breeze, just, to make a steady but slow progress. Then out came twenty or more of the local fishing fleet. Obviously we were showing our sailing lights, but I'm not sure this was a thing they see often in those waters. Churning up the sea in light airs made it a bit of a sailing challenge. However we eventually made it round the breakwater not long before dawn and more or less drifted to a suitable spot and dropped the anchor. Managed to set it with a bit of backing the main plus an ebb tide.
Happy with that, coffee and bacon sarny time. Around 0800 I called the marina. Their best option was to nip out with their rib and get us in to the marina for a diver to work. So excellent help from them, a simple alongside tow with the rib doing the power, me doing the steering onto a straightforward berth. Ten minutes later the diver arrives. Quick look under stern and bobs back up laughing away. He's seen the problem. On tanks and after a couple of minutes, four large floats hit the surface. Took him another twenty minutes to clear the junk away. Total cost of that was, tow and diver, something daft like 40 euros. I think the owner tipped them more than that!
So, mission accomplished. I excercised the gear lever a bit, then fired up the engine and gave it a good test ahead and astern. All back to normal.
At that stage it would probably have been prudent to get a shower and some sleep. But boys being boys, we went ashore and got pissed instead. ???
Hoot with the owls, soar with the Eagles. And never, ever drink at sea.Getting pissed seems to figure greatly on your delivery trips, I doubt my liver could stand one so I hope you wouldn't be offended should I ever be in need of a delivery skipper if I looked elsewhere . ? ? ? ?
I don't disagree, but maybe the time for that would be if and when the skipper decides he's ready to tell the tale.People need to discuss other people's mistakes and misfortunes in the hope that our own mistakes might be avoided, or failing that , original.
She is a kalik 40 Kalik 40 - WikipediaAny ideas what make of boat it is? Difficult to identify from the pictures.
I don't think it's just about depth, but crabs and such are often found around the rocks and 'interesting' bits of seabed, not the flat sand/mud bits.I wonder what the optimum depth is for crab pots.
On the East Coast it seems to be around the 2m contour for crabs. For nets somewhat deeper. Long liners seem to have a guard boat around and generally are much better marked.
When dark, I suppose like others , I make for the deepest water possible.
I couldn't possibly tell you how good a Sigma 33 can be at towing strings of crab pots.With respect you sound like a man that has never snagged a pot line. Rocna would be envious of the lateral holding power of a string of 20 or more pots which in the real world are laid alongside wrecks and rock outcrops as a rule ?
Depth is no protection. In the Clyde I've often seen them in 50m or more - people have reported them in 100m. And when coming south from Whitby, we saw lots in 10-20m. As noted by @Wing Mark , it's about the nature of the seabed, not about depth. Fishermen tend to have areas staked out that they don't publicise - they don't want others to fish "their" patch!I wonder what the optimum depth is for crab pots.
Indeed, I have not snagged a pot in my little Sonata, but I have been on a survey vessel that snagged creel line on camera gear, and in freeing the stuff a boathook got sent off like a javelin under the tension.One at a time with a pot hauler !,
