Worn winch self-tailors.
AndrewB
7 Jun 2001
Dover/Corfu
My old Lewmar 43ST winches are still in excellent condition, apart from the self-tailors which are worn and no longer grip the sheets well. Spares seem no longer obtainable. Is there any way of renovating or resharpening self-tailor blades?
(I would also welcome the opinion of anyone who has retrofitted Barton Winchers or similar on how well they work, though this is rather an expensive solution).
thinwater
12 Dec 2013
Deale, MD, USA
sail-delmarva.blogspot.com
Some dumb suggestions you have probably considered:
  • Different ropes.
  • One more turn on the drum. There should be very little load on the jaws.
  • Perhaps it is the drum that is worn? The can be replaced or retextured by peening.
  • Station a cam cleat down stream to hold the tail.
  • In the future, keep the winches covered to reduce UV damamge to the plastic bits.
geem
27 Apr 2006
Caribbean
Are they Waveline winches? Identifiable by the 4 screws on top?
Stemar
12 Sep 2001
I had Winchers on the non-self tailers on my Snapdragon. They worked well enough and were a big improvement over the plain winches on their own, but they fall well short of proper self tailing winches.
I'd try Thinwater's suggestion of a turn or two more on the main body of the winch first, because I'm not sure how you'd put Winchers on a knackered self tailer.
geem
27 Apr 2006
Caribbean
If they are Waveline winches, there is a guy in the UK doing a conversion to true Lewmar ST with the the sprung jaw. He converted our worn out Waveline winches. The difference is amazing. Very happy with them
AndrewB
7 Jun 2001
Dover/Corfu
They are as below, marked 'Lewmar'. I've hunted around, but no-one I found has spare self-tailors though other parts are available. I'd appreciate contact details for your guy, please!
dankilb
23 Jan 2008
Those are Waveline.
Tony Cobden 07588767893. Best to use WhatsApp
Great tip - thanks geem
We've got a set of Wavelines in otherwise good condition (and recently removed and reconditioned - as much as possible - by me) and I've often worried about what we'd do if the ST 'jaws' (I think Lewmar called it the 'crown'?) needed replacing.
I did ask Andy who sells Lewmar spares via eBay and is often recommended on here. He confirmed that new-old stock of Waveline tailing parts were now mostly unavailable (whereas many other parts still are). He suggested 3d printing as a possible future alternative. Given how critical and visible that part is, replacement with an actual Lewmar part would obviously be preferable.
geem
27 Apr 2006
Caribbean
Here is one of our Lewmar 43 Waveline converted to Lewmar ST spung jawreceived_674530164173890.jpeg
dankilb
23 Jan 2008
I think it was about £200 a winch when we had our 43s done. Compared to cost of new its a big saving.
Absolutely. The fact we’re all otherwise praising their condition after 30+ years (ours are 33!) attests to their quality and value. We’re lucky to have had them fitted to our boats back then - the replacement cost/implications are eyewatering and new wouldn’t be substantively different/better (IMHO and for our needs at least). “Up the wavelines”, I say!
Daydream believer
6 Oct 2012
Southminster, essex
This is a total long shot but may be an idea
I assume you mean that the ridges on the 2 tapered rings, or jaws, have worn away & lost their grip
Are the rings aluminium?- I assume that they are metal of some sort & not a carbon plastic. It would still work with plastic though
Remove the top disc
I would use my Mill, but you would not have access to one. So try this:-
Use a die grinder to machine the space between the ridges 2mm deeper. Thus making the ridges 2mm taller & more effective. Then put the disc in a lathe & reduce the flat shoulder 2mm, so the disc sits lower & closes the "V"gap. Then fit a 2mm washer on top to take up the slack. The top disc is already worn so it is worth a go. If it works you could repeat for the top of the main drum, but without the lathe work
You should be able to get an air powered die grinder with grindstones for under £50 then hire an air compressor from a hire shop. The whole process might be cheaper than buying replacement parts.
Any model engineer with a lathe will machine the shoulder off the disc for you in an hour. I would do that part for a beer.
awol
4 Jan 2005
Me - Edinburgh; Boat - in the west
Today I discovered that if the screws in the top are hex-socket screws rather than cross-head, indicating even older, there is no off the shelf solution. The lower jaw is part of the drum with these. I am investigating casting and machining at the moment, scanning and 3-D printing in metal seems a tad OTT but .........
