HMSOptimus
New Member
Hello All,
I am looking for some help and advise. I have wooden boat, built in 1962. The frame is built from Iroko and I have a spot of rot in the main beams.
The P Bracket is bolted through with a plate on top. I notice these are connected with a number of wires, assuming going back to a battery (not sure) and I think some electrolysis or something has caused the beam to rot and the plate is green with white powered like you would find on a battery. It is localised to under the plate only, and this is the worst area. the other beams and brackets haven't been affected at all as much or at all.
I have an idea of removing the plate, scraping out all the rot and lose timber making a U shape and treating it. Then each side of the beam, putting in a longer and thicker piece to make is stronger and sistering it, bolting it through to increase the structural strength of the existing beam, wider and longer.
Then with the U shape void, pour some epoxy resin in to soak into the timber fibres and then put a new piece of wood in and pour some more epoxy resin to make the old beam complete again and reinforced.
I am asking, how would you suggest to fix this without taking all the planks apart and put new beams in, or any ideas. Also anyone know how this could have happened as the rest of the beam is solid and not damp or wet.
Thank you in advance,
David
David
