Champagne Murphy
Just seen a thread which mentioned these. Any recommendations?
For the money the little Alfa wifi ones are hard to beat. Ours the 2000w version has done sterling work for the past 4 years. Make sure you buy a genuine one.
I have also used the Alfa and it is excellent. I purchased the version that included the panel aerial but this can be purchased separately. The panel aerial gives even better results than the standard di-pole. http://www.ebay.co.uk/itm/like/3810...1=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108&ff19=0
Errrrr......... I know I'm a bit thick but what does that all mean? Can I use it with Android and Mac? Does it use a lot of power? Will it work of a 12v supply or does it have to be 240v. When it picks up the signal from the router does it have to plug into the computer with a USB?
Cheers
Well, it's white, wasn't quite 10x and actually does seem to be waterproof but he's roughly right.repackaged into pretty colored boxes allegedly waterproof and sold for 10+ times the price
Cheers
At the end of the day you can only "suck in" what is available. Whatever your receiver,
it's down to the transmitter>
Thanks for the recommendation. Brilliant bit of software. Just does what it does, no hassle no fuss. Superb.The Alfa plugs into a computer via USB (which powers it) and is an alternative to the WiFi receiver that is built into the computer which will need to be temporarily disabled while the external aerial is used. The panel aerial improves the boosted signal (over the di-pole) but is directional.
Your computer can be turned into a hotspot for other devices to latch onto the incoming WiFi signal simply by installing software such as "VitualRouter"
Twaddle.... One problem we found in some out of the way places was a tendency to pick up viruses when accessing free wifi-be warned...
Twaddle.
I only speak from experience .Twaddle.
Twaddle.
