Why arm power and no pedals this time?
ltcom
27 Mar 2017
Has this been asked? Sorry if so. The catamarans used pedal power...... strong legs, low centre of gravity, these boats are back to arm grinders. Is there a design reason?
dunedin
3 Feb 2004
Also they are not catamarans, they are an aircraft that drag a foil or two through the water.?
Yes but the the OP was referring to the previous generation AC boats, which were foiling catamaran style, and one boat (the winners?) used leg/pedal power rather than arm/winch power.
Why more efficient pedal power was banned by the new rules is odd, but just like moving from light catamarans to lead balanced monohulls, the new rules seemed less about speed / efficiency and more about being different from the previous ones.
NormanB
20 Oct 2014
Are you here for a 5 minute argument or the full half hour?
I was being light hearted hence the emoticon.?
ltcom
27 Mar 2017
Right. Thank you. Quite enjoying parts of the series now. A bit like Day of the Triffids machines on water. Wish I was there. Sailing a bit boring, but interesting to see how the tech works out ...... or not.
dunedin
3 Feb 2004
I thought hydraulics did all the moving and the batteries were needed for the computers controlling everything?
Really good video explanation of the crewing roles and how each team operates the roles slightly differently PlanetSail: AC75 Crew Work Explained Part 1
And apparently “everything below the water is operated by battery, everything above the deck by hydraulics (or winch)”
Tomahawk
5 Sep 2010
Where life is good
but going back to the OP... I am wondering why no cycling grinders?
Legs are far more powerful. OK, it would mean possibly loosing one/two crew members to compensate for the extra power?
I always wonder why none of the IMOCA designers use pedal power for grinding up things like the main? I am sur a bit of imagination would put together a position where you can cycle from one side or stand up and grind fron the other. .
LittleSister
12 Nov 2007
But that doesn't explain how the hydraulics are powered.
If you want to make it easy, why not just install engines instead of faffing about with flappy things?
Tomahawk
5 Sep 2010
Where life is good
Sailing boats have traditionally been made of wood with he,p ropes and cotton canvas.
Given the costs of these hugh tech marvels, it would probably be cheaper to go back to J Class?
flaming
24 Mar 2004
One did this time round.
flaming
24 Mar 2004
The simple reason why no cyclors in this cup cycle is that even TNZ agreed that it looked really stupid last time. And they wanted to go back to having sailors on the boats, rather than bringing in TDF cyclists just for the power.
