dom
Most designers calculate empty displacements for stability purposes, (sans safety gear et all and sometimes without furling systems) and most manufacturers like to quote these numbers in their publications. Remember, heavy = bad. This is how the yachting press "tests" these boats as well.
...If, as I have said before, a lot of nonsense has been written about sailing speeds, generally by over-exaggeration, displacement has to be a close second by gross understatement.
Fudging the numbers on speed? Who cares. Fudging the numbers on displacement is a lot more sinister: it not only affects speed (Nooo!) but more importantly, stability, safety and sea-keeping.
Regarding stability, no adding weight is not always bad for stability and it is nonsense to say so.
Think of water and fuel tanks carefully moulded to fit shapes close to the bottom of the boat. Or engines, batteries, generators, indeed anything bolted down or otherwise firmly secured below the centre of gravity. Which is why ships take on ballast for ....erm heavy weather
Weight up high on deck or aloft is another matter. All explained in Figs 3 & 4 in the attached MCA link on Fishing Vessel Stability, which is well worth a flick through for anybody interested in stability:
https://assets.publishing.service.g...CGA-Fishing_Vessel_Stability_Guidance-WEB.pdf
