Whitlock 30nch wheel
dunkelly
28 Aug 2018
Changed my wheel up to 36 inch a while ago and keep this as a just in case , since sold the boat and still have this , the new one cost over £350 but I'm open to serious offers around £100 .
dunkelly
28 Aug 2018
Hi there. Is the wheel brand new or the one you took off the boat please?
Hi , it is the original wheel but was only on the boat for a year or so and barely used . I bought the boat an endurance 51 and immediately realised with some small mods to the cockpit we could accommodate a 36 wheel which had a significant impact on the loads on the helm . So it wasn't taken off because it had damage or any defects it's still in very good condition just old . Btw it's a tapered keyway fitting .Nigel
dunkelly
28 Aug 2018
No problem Paul . If you decide you need it at any point send me a pic of yours and I'll be able to tell you . Nige
dunkelly
28 Aug 2018
I will try again, got my wheel off at last is this what your look like? Assuming you still have it that is.?
Hi Paul yes I do still have it . Definitely looks like that, not sure about the taper size however . It's at home in the garage so I can't measure it until I'm back after new year unfortunately . Nigel
dunkelly
28 Aug 2018
Hi Paul . Yes it is the diameter . I had to think then for a minute with the modern trend towards these huge wheels - but definitely the diameter . I'll check when I get back, the boss depth and entry and exit diameters . N
dunkelly
28 Aug 2018
Hi Paul finally home and checked the wheel dimensions . The boss is 25mm deep and the taper is 25mm - 18mm Over the 25mm . Which I think is bigger than yours looks . A cone would be a simple thing to get made if you wanted it they may even have one at Whitlock's . N
dunkelly
28 Aug 2018
Hi Paul . Hopefully attached some pictures . It looks a bit dirty sorry I'll will polish it up before it goes ! The guys name at Whitlock is Cliff . I've spoken to him a few times but never thought to ask about a spacer . Nigel
