skipmac
Over the years I have used and carried all sorts of knives; basic riggers knives with one blade and a marlin spike, single fixed blade sheath knife, various Swiss Army knives, a Leatherman wave and a Gerber (forget the model but equivalent to the Wave).
First, I do have a very complete set of tools on board but I keep a multitool in a belt case and use it constantly as it saves running back and forth to get tools when I'm puttering about on the boat. Also going up the mast it is handy as it has most of the tools I would need all together. All that being said, one of my favorites knives is the Victorinox but for boat use I miss the pliers and locking blade.
The Wave I have had for years and overall love it. The Gerber is a much higher quality, better made knife but a couple of things make it less functional than the Wave. First the knife blades are much smaller than I prefer and occasionally not large enough for the job. Also not as easy to open one handed as the Wave plus the Wave you can tell by touch if you're opening the straight or serrated blade.
About the only thing I really hate about the Wave, if you aren't careful using the pliers they will hurt you very meanly. When you squeeze the handles tight there's no gap next to the hinge and if a bit of skin gets in there you will get a nasty pinch. The Gerber is designed with a gap between the handles even when the jaws of the pliers are fully closed so won't do this.
Has anyone tried the Wave Plus? Wonder if they have fixed that in the new version.
One final comment, while the Wave is excellent grade stainless it will corrode. I used it for something out in the dinghy and had to rinse it in salt water. Didn't think to rinse it in fresh when back on the boat and didn't use the knife for a few days. When I did there was a bit of surface rust on the knife that wiped right off BUT all the blades and tools were extremely stiff from corrosion in the joints. Some oil and working the knife for a while cured it but I'm more careful about salt water now.
