Frogmogman
I’m in the market for a new handheld VHF, and am thinking of buying a Standard Horizon HX890.
Any of you have any better ideas ?
The fixed is a Raymarine RAY 70, which also has a second handset and speaker at the helm, so it’s not like I need the handheld for when I want to use the VHF in the cockpit, it’s more as a back-up and to take in the life raft (god forbid).A lot depends on which make of fixed VHF you have. Much easier to have just one set of menus and buttons to navigate. I have a Standard Horizon HX870, which I presume is an earlier model and it works well and a Standard Horizon fixed VHF and the controls are identical.
Was that the basic £50 one? I use a 325 model which was about £80 some years ago and has been fine for my limited use. Always works and battery holds charge well.My Cobra was cheap shyte and never really worked well. It was always making static noise and setting the squelch at maximum would not get rid of it. The only solution was to hold a hand around the aerial. It went in the bin. One not to buy.
I have the old version of this and it's a great radio, but if I were to buy now I'd go for something more portable as these DSC sets are massive. Realistically the use of DSC in a handheld is quite niche so if you have a fixed set as well just get a small portable. The reality is that due to the size you won't have this on you if you go in the water so any dreams of enhanced safety probably won't come true.Standard Horizon HX890.
I have one. It‘s fine.I’m in the market for a new handheld VHF, and am thinking of buying a Standard Horizon HX890.
