RogerJolly
Just an Eberspacher Hydronic. These heat water instead of air and either use radiators or heat exchangers (little radiators with fans) to heat the boat. The big bonus is they can also be plumbed in through the calorifier to heat hot water without using the engine, and in winter can heat the engine before starting. Larger boats use these as there is less heat loss going from one end of the boat to the other with insulated water pipes, and it's more flexible on placement of heat exchangers.
As I said, we have an Airtronic which I love to bits, but Hydronic would be my preference going forward.
Aha, will look into thanks. Never liked the idea of boring big ducting holes in the boat, guessing water pipe holes will be smaller. in the Probably be a bit OTT for my little boat though.
My £1000 might go on moving main sheet from cockpit sole to coach roof, on a traveller.
Hopefully with change, but with me a lot will disappear in wastage - bits bought that are wrong in some way - size, type etc., mis-conceived arrangements.
