Captain Crisp
Any advice on the best sort of perspex to use? I sleep under it, so need to get it right!
Thanks,
Crisp
Thanks,
Crisp
To add to what alahol2 just said. Acrylic can come in different grades, some deteriorate quicker than others in uv/sunlight but the Perspex brand is one of the better ones and when you buy the sheet the protective film on both sides that it comes with will be printed with the Perspex name. There are many suppliers but I have bought from Cut to Size Acrylic (Perspex) Sheet, Tube & Rod - Simply Plastics who gave good service.Any advice on the best sort of perspex to use? I sleep under it, so need to get it right!
Thanks,
Crisp
He is only asking what type of material to use for this type of application, no need to go in to detail about the whys and wherefores!Another case for more information.
Pictures (which will determine how the hatch is constructed (frame, no frame etc), actual size, Why do you need another hatch, is it crazed, crack developing etc.
With more information you would receive precise details.
Jonathan
Thank you for the instructions - which I will ignore.He is only asking what type of material to use for this type of application, no need to go in to detail about the whys and wherefores!
Nobody has so far mentioned that polycarbonate without UV protection should be avoided.Polycarbonate (aka Lexan) is more forgiving, easier to work, much stronger (used for windscreens in planes and trains, car front/head lights etc.).
Comes in different colours/tint too.
I made a new windscreen for the flybridge. Cut with a jigsaw, detailed with a router to copy the original 1:1. Easy..
Sorry for the yankee style, but good info a bit into it:
Apologies for not being more specific - it's a fairly straightforward design on my 50yr old Twister. The current perspex is unpleasantly yellowed and cloudy.
I think have an unused piece of 12mm thick grey-tinted acrylic sheet that might do. What dimensions do you need?Any advice on the best sort of perspex to use? I sleep under it, so need to get it right!
Thanks,
Crisp
That's very kind - I'm at work but will measure up later and get back to you, Poignard!I have an unused piece of 12mm thick grey-tinted acrylic sheet that might do. What dimensions do you need?
Agree. It is easy to identify an acrylic brand eg Perspex, that comes with a good uv resistance guarantee so you will have to search for a marked brand of polycarbonate sheet with an equivalent uv resistance guarantee.. Good uv resistant polycarbonate does not need a protective layer as demonstrated by car headlamps, the vast majority of which will be very clear at 20+ years without a protective layer.Nobody has so far mentioned that polycarbonate without UV protection should be avoided.
A previous owner of our boat fitted polycarb windows that had gone so badly ‘milky’ after a few years they were opaque. Our local plastics engineering place said it was typical of cheaper polycarb (technically sold for us indoors apparently - e.g. till/POS screens).
More expensive branded varieties have a UV protection layer.
We replaced the milky windows with 10mm tint acrylic (unbranded - but I can attest still frighteningly expensive - as I couldn’t source genuine Perspex anywhere without buying an entire sheet!). They look great and acrylic seemed easy to ‘work’ with standard tools.
Perspex brand is easily identified by the protective film.
