What Three Words
Adios
20 Sep 2020
This is true, the app generates 3 words from the GPS position offline.
But communicating that to anyone lese generally requires a phone signal.
SMS will work when phone signals are very weak or in high interference conditions.
Much more reliable than speaking 3 incoherent words.
You have the possiblity of the originator misreading the words, the recipient mishearing or mistyping them.
And if it used SMS there is no reason to not keep using lat and long
Mark-1
22 Sep 2008
The SMS solutions all require data. (Perhaps surprisingly.) If they didn't I'd agree it would be a slam dunk.
Mark-1
22 Sep 2008
______Which is interesting. None of my position apps directly create a SMS for me. W3W lets me copy my position to a buffer, but it's not as good as creating a text message for me. Wonder why they don't. It would solve all the other problems.______
I'm wrong they all do - simply using the share button.
RobbieW
24 Jun 2007
On land for now
Based on what I glean from a router forum I follow, I'm not convinced that is true in all implementations - it may be for 5G but in the UK using 4G I'm pretty sure the services are seperate and SMS will get through where other connections wont
Mark-1
22 Sep 2008
That's true.
...but the SMS location 'requesters' SARLOC etc, all require data AFAIK.
Adios
20 Sep 2020
That's true.
Never heard of requesters but i was thinking it would be simple to create a feature in a phone that puts position lat and long in a standard text message.
Its so obvious I wonder why it doesn't already exist.
Mark-1
22 Sep 2008
It does, the share button on the location app of your choice. I confess I only clocked that tonight hence my correction above .
The W3W app does it in both W3W and lat/long format. (Or the settings imply that).
Adios
20 Sep 2020
I mean why there isn't a sos text with location feature as a part of the standard OS, on the lock screen, press a few buttons to operate. You used to be able to call 999 without unlocking the phones but thats not possible on my iphone now that i can see.
Mark-1
22 Sep 2008
Code:
https://w3w.co/irrecoverable.feasts.unlicensed
///irrecoverable.feasts.unlicensed
50.368949, -0.997317
This 3 word address refers to an exact 3m x 3m location. Tap the link or enter the 3 words into the free what3words app to find it.
That's the contents of the text the W3W app generates for you.
Code:
Dropped pin
https://maps.app.goo.gl/v5HHoJZoBRceTsiD7
...and that's Google maps.
Up until now (from a big boat sailing POV) I thought of W3W as something you'd be handling as a receiver from a kayak in distress or somesuch rather than transmitting. Strikes me that if you have signal in an emergency situation you really might as well send a text/WhatsApp from your chosen position app as well as the routine EPIRB/PLB/VHF stuff. It can't hurt. Depending on the circumstances, if the boat has several people on board with phones and nothing to do they might as well be sending the position out too... I guess there's a risk of overloading the CG but in many circumstances to many is probably better than too few.
Adios
20 Sep 2020
Code:
Are you out fishing?
No reason not to use that app then having both (unless it data mines our phones of course). I wonder which the emergency services will use when offered both though? If its not integrated well at their end and they need to type it into another system its easy to type 50.36 -0.99 while potential for misspelling those three words
Mark-1
22 Sep 2008
My pre-bed time swim. Very refreshing.
From overheard CG traffic it's clear they like a lat long format. (Causing a somewhat frustrating delay when someone has given a cast iron pinpoint like "I'm clinging to "Coronation", Southapton Water." and then has to spend precious tens of seconds reading out Lat Long. )
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
I'm certain that is not true. I keep phone data switched off, but I can use SMS fine. There is also a trap that if you put fancy emoticons in a SMS message it may switch to data to be able to encode it because it is not a regular character. But I don't do that either...
TernVI
8 Jul 2020
What do you mean 'data'?
Since 2G a phone call is 'data'.
SMS needs less in the way of comms between a phone and a basestation than voice does. SMS will get through when nothing else will.
Mark-1
22 Sep 2008
I'm talking about the SAR SMS solutions, Phonefind, SARLOC etc.
Obvs you don't need data to send an SMS.
Mark-1
22 Sep 2008
I take data to mean 'internet', I've never heard it used in any other context.
Agree re SMS as I did earlier, don't think there's any doubt about that.
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
Are you confusing the words "data" and "digital"? If you look at phone charging they distinguish voice, text and data. That seems a good enough set of definitions to me. And I guess by "less in the way of comms" you are talking about signal quality, which phones usually display. As GPS devices (whether or not embedded in a phone) often also display for the absolutely separate GPS satellite signals.
Adios
20 Sep 2020
Yes its all digital data since 2g. Its over my head mostly but its clear SMS over GSM is not the same digital data service as internet data even when a phone is 3 or 4 G for data
"While SMS is still a growing market, it is being increasingly challenged by Internet Protocol-based messaging services such as Apple's iMessage, Facebook Messenger, WhatsApp, Viber, WeChat" SMS - Wikipedia
In use its frequently the case that my phone looses the 3G while I still have the ability to send a text. And it will keep trying to send with any momentary bit of signal where a voice call wouldn't work. So have to wonder why text messaging isn't more integrated for emergency functions
