crisjones
Our watermaker water is at least as good as bottled water and usually much better than most shore supplies in the Med. Our guests always say how pure and fresh it tastes. Our ppm tester shows around 150ppm for our watermaker, 200-400 is normal for shore supplies and in some Greek Islands it can be much worse.
Our water goes straight into our main tanks and our galley tap has a carbon block filter on it and this is the tap we use for drinking and cooking water. We have been drinking mainly watermaker water for the last 8 summers and have never had any problems, nor have we ever bought bottled water for the boat.
There are some reports that suggest watermaker water may be lacking in some minerals that you would normally get in shore or bottled water and this may cause problems if you drink exclusively watermaker water over long periods of time. Personally I think if you have a good balanced diet along with a few beers and wines then I doubt you will have any problems at all. Watermaker water is also free from added fluoride that has been linked to some serious health issues as well as the promoted benefit to teeth and gums.
We also have a system for collecting rain water, this is passed through a carbon filter and a 5 micron filter before it goes into our tanks, again we have had no ill effects. Rain water is usually around 50-100ppm so is generally very pure. We would not collect rainwater that is full of red Sahara dust that is pretty common in the Med when winds are from the South.
