Ariadne
Just found I have some very thick grey sludgy oil in my engine (Volvo Penta MD21B) so What I need to know is where is the water coming from? I changed the oil only 20 hours (although dirty black as normal it was water free) or so ago and replaced the head gasket and had the head skimmed last June so its only done about 200 hours.
I've had the oil cooler off and that seems to be OK, I would assume that as the oil is under pressure it would leek to the water, not the other way around? I don't think there is a way for the sea water to leek into the engine via the salt water pump, in any case the water drains out through purpose built holes when the seals go. So can I now assume it is the head gasket that has gone?
Any thoughts from the engineers out there?
