Jokani
In the process of curing an oil leak I completed the following work:
Since putting it back together it will not fire.
I have checked:
I have tried cranking with easy start and it still will not fire.
The problem seems to be a lack of compression, I can turn the engine fairly easily just with 2 hands on the crankshaft pulley.
Clearly I have re-assembled something incorrectly - I would suspect the timing, but I am 100% sure that the timing gear markings are correct.
Any ideas of how I could have reassembled incorrectly to cause the low compression, and/or the next steps I should take?
Thanks in advance, Gary.
- Removed timing gear cover
- Removed intermediate gear - when replaced ensured timing markings were correct, and to be 100% sure I removed the timing gear casing again and had another someone else verify they were correct
- Injection pump removed and replaced
I have checked:
- Clean fuel with no air at the injectors
- Glow plugs working correctly & 12v+ at power bar
- Stop control is working correctly and in the correct position
