Jcorstorphine
From what you have said I am confident the timing is correct. At a compression ratio of 23 ish to 1 it will be quite hard to turn over by hand. If it isn't then compression is the problem, but why? Thinking on, did you take the camshaft out? If so did you replace the cambuckets etc in the same places? Did you reset the tappets?
Stu[/QUOTE
You could take off the valve cover as this would give an indication if the valves were actually sticking and then being closed by the piston pushing them home.
The OP also mentioned in his last post that cylinder 3 regained its compression. Is it possible, one of the gears is slipping relative to it corresponding shaft. Are the gears on a cone similar to an OHC engine and have to be set against a timing pin or timing mark or are they on a key. Need to read the manual to find answer.
