Fire99
Hi All,
Well the saga of the AQ200d V8 Petrol engine continues.
I drained the tank down at the weekend and replaced the fuel.
After much adoo the engine ran fine on the pontoon and under light load. Took her for a run and faltered when the revs rose and the engine just wanted to fade away..
Anyway, today after double checking water trap filter / mesh carb filter etc.. engine ran perfectly in the Marina... tested under light load and without for a reasonable time..
Took her for a run and all the way out the creek at low load she ran fine.. pushed the throttle down and she was hesitant finally not getting further than 2.5k - 3k revs.. then faded away and died... then refused to restart at all.. would fire then immediately fail.
Anway after a very vaulable tow back to Tollesbury.. left for an hour or 2 and then restarted fine even under light load!!! annoying? very!
Anyway after a chat down the marina the current guess is Electrical since the fuel all seems ok. Possibly a breaking down coil?? what do you guys think?
Anyway.. a couple of questions.. where can i get a replacement coil for reasonable money.. (Its the one with the resister bolted on the side)?
And while im at it, do you know where i can get a bolt on electronic ignition module for the engine? (ive heard a few people talking about them)
Anyway a bit downhearted on this one at the mo (after all the great weather this weekend) so any help as ever is appreciated... (before i give up and defect to sailing..)
thanks,
Nik
thanks,
Nik
