vas
oops, didn't realise it was last year's thread, so deleted, no point in continuing this debate...
I’ve never asked such a personal question before but what is your anchor?oops, didn't realise it was last year's thread, so deleted, no point in continuing this debate...
mr Bouba don't expect an answer on this sensitive issue unless you post in the relevant MB thread a pic of the placement of your passereleI’ve never asked such a personal question before but what is your anchor?
Jonathan, you know my worries about the methodology of Panope Videos. This is another great example of him switching things about.I had a thread on Panope Videos.
This video simply underlines some of my concerns.
That material is remarkably strong, 90 ton steel in old money and yet still very ductile, Charpy figure 27 joules. These boron steels had not been heard of when I studied, amazing stuff. My only reservation for anchor duties is the 0.27 carbon, I understood there were rules about not exceeding 0.21 for anchoring gear?Viking Anchors are really hammered by the idea that an anchor needs to be heavy - yet there is no evidence that weight is a factor in anchor performance. Size matters, not weight - so a bigger anchor (of the same design) has more 'potential' hold than a smaller one. As most anchors of the same design are made from steel a bigger anchor (with that extra hold) is also heavier - weight is an easy characteristic to measure - which leads to the conclusion that heavier anchors are better than lighter ones. But all the research suggests, almost, the opposite. Other evidence is to compare the performance of a Fortress and a Danforth (whose designs are not identical) but in tests a Fortress is invariably better than a Danforth. Another factor allowing improved performance of Fortress over Danforth is the thinner fluke of the Fortress which allows better, or easier, penetration. We use an aluminium Excel and a aluminium Spade and have used the similarly sized equivalents in steel (which roughly weight twice as much as the aluminium versions) and in terms of speed of setting and hold - we cannot tell the difference.
Viking are using Hardox450 from SSAB which has a tensile strength of about 1490 Mpa, almost twice the strength of Bisplate 80 used in the shank of the original , NZ made Rocna. Original Rocna had their HT shank and a fluke fabricated from Q235, approximately a 425 Mpa. Viking are using a steel in the fluke with 3 times the strength - allowing significant potential for weight savings.
As we use aluminium anchors we are obviously weight conscious and would use a Viking anchor - if it fitted on our bow roller. Having tested the 10kg Viking - its as good as the 15kg Excel and Spade.
Sadly this advantage of the Viking falls on deaf ears, many experts don't appreciate the advantages (or don't want to) and the religion of weight is a difficult one to overcome.
To me extending Peter Smith's use of high tensile steels from the shank to the rest of the anchor looks to be a positive move - it is strange it has taken so long. Now whether the market will accept the idea - of a lighter anchor having the same performance of a heavier version - time will tell.
Jonathan
I have a little 2 lb Viking aluminium anchor made in the USA in the late 70's - it looks just like a smaller version of a typical Fortress anchor (even with the way it is bolted together). I am wondering if these Viking folk were the forerunners of Fortress?
And it has impressive holding power - it held a 38' 10 tonne sailing yacht on a rope rode (no chain, but lots of scope) in average sand in about 10- 12 knots of wind quite happily. Yes, just 2 lbs.
See one of the Z shank tests on a Viking 20 (3 tons pull on the toe)
