MapisM
Yep, I was aware of the possibility to split AC high and low loads, using AC-1 OUT (which is also inverter powered) and AC-2 OUT (which just passes through AC shore power, if and when present).There are ways you can automatically do some of that, such as split the system into high current devices and low current devices
And in principle I would have liked to exploit that, but I should have routed an additional pair of sizeable wires from the lazarette astern, through the e/r, and eventually to the general electrical panel amidship. On top of that, existing tubes are already full enough to make snaking additional cables inside them optimistic to say the least.
So, considering that it would have been just a nice to have, I followed the KIS principle!
Interesting to have a confirmation, thanks again!So that confirms our suspicions, you do need the MK3 device. I would say it's well worth having.
I guess I'll byte the bullet and buy an MK3 interface, also because it's not a huge bullet anyway.
That said, using instead Victron Connect on the mobile and install a bluetooth VE Bus Smart Dongle on the Multiplus wouldn't allow also the firmware upgrade, or would it? Interestingly, when I use Victron Connect to "see" the Smart Shunt, among other screens there is one suggesting that it can be used also for firmware upgrades - with the Smart Shunt, at least (see below).
That would be a much more convenient alternative to the MK3 interface, because for "ordinary" system monitoring it's obviously easier and quicker to use the smartphone rather than turn the notebook on and physically connect it to the Multiplus...
