That is a gps antenna, which should be connected to a gps receiver. It is the the gps receiver that can connect to the vhf, not the antenna, if you weren’t awareI’m assuming this is a GPS receiver.. but stand to be corrected if not.
Now I know which wires are required I will see what is there?
No I didn’t know that. I need to get the panel off now and chase the wiring, see what’s actually there.. maybe there is a receiver and it will be as simple as connect up. I doubt it though.That is a gps antenna, which should be connected to a gps receiver. It is the the gps receiver that can connect to the vhf, not the antenna, if you weren’t aware
That depends ... NMEA0183 version 1 is single ended like you describe, however v2 is differential so the other post isn't necessarily wrong. Fortunately v1 and v2 devices can still even be wired up to each other (if the OP needs to get into that), for instance this web site describes the wiringTwo wires ....
NMEA out from GPS Receiver ... connects to NMEA In at radio.
The second wire is the NMEA GROUND and this connects to the negative lead of radio ... most boats have common ground of instruments - but its often good policy to ground locally anyway.
A post earlier said NMEA + and NMEA - to be used ... not correct. Unless post meant NMEA + of one unit to NMEA - of other unit. He forgot the GND wire.
I mentioned NMEA + and NMEA -, this was after reading the user manual for this particular DSC VHF.Two wires ....
I was going to order one of these but I see the default baud rate is 9600. How easy is it to change to 4800 as required for interfacing to other systems?A simple separate way to 'GPS" a radio is to use a GPS Module such as sold by Banggood / AliExpress / Amazon and other online sellers. For less than 20 euros you get a module that is a) highly accurate, b) as small as a 50p piece and even smaller, c) you can double side tape to the radio out of sight.
It will need a BEC (about 5 - 10 euros) that reduces 12V to 5V ....
I am just waiting for replacement module myself after using my spare on another project.
GPS/GLONASS-Modul Beitian BN-220ZF mit hoher Genauigkeit, 72 Kanälen und NMEA-0183-Protokoll. Kompakte Größe ideal für FPV-Flugzeuge, Drohnen und Roboternavigationssysteme
Just have to read sales page to make sure module has NMEA 0183 ....
To give an idea of their accuracy and reliability - they provide the GPS positioning of expensive and highly agile drones ... even to autonomous flight capability. Far more than needed by a VHF.
I have two current DSC radios and both accept NMEA as I described .... 0183 generally predates DSC by a wide margin.I mentioned NMEA + and NMEA -, this was after reading the user manual for this particular DSC VHF.
I'm pretty sure that NMEA v1 predates DSC. Have attached a simple connection diagram for reference.
That is a standard 8 pin Din plug. Amazon sell 8 pin Din sockets to fitHello all,
Would anybody please be able to advise on this radio. I’d like to connect a GPS receiver to it so I can get position displayed.
could anyone advise what I would need to for it please?
Thank you..
View attachment 164173View attachment 164174
