aidancoughlan
Has anyone here with an XB-8000 had the AIS output over NMEA/WIFI stop working .... would like to hear any advice if you learnt anything from it.
My XB-8000 AIS Trasceiver used to transmit a local WIFI network which could be picked up on Mobile devices to show an AIS radar style display in the "Watchmate" app. However, it seems to have stopped transmitting a WIFI network - I can't detect one on phones, laptop etc. It seems to have also stopped sending AIS data to the Raymarine Plotter over NMEA (which used to work before). I've not been afloat since the season before last, so I can't confirm if they both stopped together.
I tried downloading the latest vmAIS Software (config utility) from Vesper, and tried resetting the WIFI SSID/Password etc. but still no WIFI output, and no AIS data on the plotter. Tried uninstalling & installing the latest watchmate app on the mobiles, and no change. The NMEA 0183 output in the Configuration utility (connected via USB) is set to 38,400 Baud (required for AIS), and is set to transmit AIS TX etc. The WIFI page in the Config utility is set to "Configure as Access Point", with IP address and Channele tc. defaulted. When I turn that OFF , the option to "Select a Network/Scan" becomes enabled - as far as I can gather it can join another existing WIFI network on board rather than creating it's own. This doesn't find any networks unfortunately (my phone is offering a WIFI hotspot, and there are several others around). I know that AIS Transmit is OK (it shows up on others receivers). I know it's GPS is working (the vmAIS PC utility confirms satellite reception OK).
Working through the symptoms, a fault in the unit itself seems likely unless I am missing something. The options to create a WIFI network, or join one both seem inoperational, and AIS data transmit over NMEA seems inoperational also , but the basic AIS TX seems OK.
Hope we can get this fixed, it's good functionality and we really missed it on our first passage across the local shipping lanes in fairly thick fog!.
