penfold
Makes a change from ramming piers.
So.....does this mean that they think Prince of Wales can be repaired without going into dry dock?
She's come in to offload "stores" as well as locking the shaft prior to her trip oop norf. Can one assume the "stores" might the the noisey, bangey things? I wouldn't think Rosyth dry dock would be too keen on working on a fully armed ship.
She's come in to offload "stores" as well as locking the shaft prior to her trip oop norf. Can one assume the "stores" might the the noisey, bangey things? I wouldn't think Rosyth dry dock would be too keen on working on a fully armed ship.![]()
Back in the day, the Clyde Submarine Base had AFD60. Fondly known as Monty Pythons Floating Dock.Yes; standard operating procedure for dry docking warships includes de-storing all ammunition before docking.
I don’t know if this can be done at Portsmouth or whether she has to visit the Clyde for this.
I was a partner in a merchant ship crew training operation which we set up on the former ammunition pier at Subic Bay, in the Philippines : it was ideal as it had been built to take super carriers, it was miles from anywhere and surrounded by jungle and it had deep water for free fall lifeboats etc.
No. Noisy bangy things don't get offloaded between Portsmouth and Gosport. That gets done in Scotland, where the population is expendible. See #207:She's come in to offload "stores" as well as locking the shaft prior to her trip oop norf. Can one assume the "stores" might the the noisey, bangey things? I wouldn't think Rosyth dry dock would be too keen on working on a fully armed ship.![]()
Secret Scotland - Crombie Munitions DepotCan ordnance not be unloaded at DM Crombie which is three miles up-river from Rosyth Naval Dockyard?![]()
The Scots might be taking the risks...but it’s the English who have to pay for the explosives....so be careful!No. Noisy bangy things don't get offloaded between Portsmouth and Gosport. That gets done in Scotland, where the population is expendible. See #207:
Not sure if she can squeeze in there and if so its possible her flight deck would overhang the narrow pier. Both ships went up to the Crombie area prior to departure so they were out in the stream ready to pass under the rail bridge at the right moment. Both ships have hinged masts to give clearance which wasn't muchNo. Noisy bangy things don't get offloaded between Portsmouth and Gosport. That gets done in Scotland, where the popolation is expendible. See #207:
If you are referring to PS Waverley, she didn't ram Brodick Peir. Arran was at fault - it had been moved!Makes a change from ramming piers.
Maybe she will indeed go toNot sure if she can squeeze in there and if so its possible her flight deck would overhang the narrow pier. Both ships went up to the Crombie area prior to departure so they were out in the stream ready to pass under the rail bridge at the right moment. Both ships have hinged masts to give clearance which wasn't much
Video shows tight squeeze under Forth Bridges as HMS Queen Elizabeth returns
Very easy to ram a pier with a paddle steamer as a certain mate that trained on our ships found out when let loose on one of the White Funnel ships in the Bristol Channel. Penarth Pier became a little shorter. The paddlers have no steerage at low speed so often there are interesting moments if things are not right at slow down time. They have to stop within heaving line distance!Makes a change from ramming piers.
Maybe she will indeed go toGlen Mallon - then through either the Caley or F&C Canal.
The pier at Glen Mallon got modified to accommodate them...
It’s got Broon’s fingerprints all over it..and the UKC in the approach is 50 centimetres.
This looks like corruption in Naval procurement.
It was the pilot's fault.You've left off the possibility it might be something less embarrassing, like a chinese Buster Crabb wrapped around the prop shaft.![]()
What a great picture, Kukri.
+1. Superb.What a great picture, Kukri.
