UK’s biggest warship suffers propeller shaft damage off south coast after setting sail for US
I think that the amazing thing is that with only two days notice another aircraft carrier is ready to go in place of Prince of Wales...
Here’s an interesting article...it’s about a Nimitz class carrier, so nuclear power so it’s much bigger and much more powerful than either of the RN carriers.....but the torsional stress on the shafts must be universal
Tactical Action Officer on a US Navy aircraft carrier tells how long does it take to a Nimitz Class aircraft carrier to go to flank speed - The Aviation Geek Club
Don't know who did that article's maths, but a prop shaft will not pretzel itself and twist 1.5 times at full power.
Since every material has a modulus of elasticity and since in operation there are opposing torsional forces on the shaft it must twist.
Article says its 184ft long and twists 540 degress. 184/540=0.341 degress of twist per foot of shaft length.
Without loads of other data, particularly the prop details and shaft material, I couldnt say if thr 540 degrees is likely.
Have another look at that little sum? The twist seems rather high to me, I don’t think I’d like to be aboard when it’s twisted 54 degrees, let alone 540.
It’s nuclear powered....I would regard the power as unlimited....and the propeller is 30 tons....I would say the biggest problem is stopping it torsioning
You think my maths is wrong?
The acceptable amount of twist very depends on the details within the mechanical design, but 184ft is a lot of shaft.
Your calc is upside down. It’s ange/length, not length/angle, to get distortion per foot. 3 degrees per foot is nuts. In fact, this 540 degree claim is much debated on the net. It’s not hard to find. When you do the sum right, you’ll realise that 540 degrees is beyond the elastic limit.
Further to that, normal design criteria would say that around 0.3 degrees of twist per foot would be acceptable, so in spite of my nervousness, 54 degrees would be acceptable. Comfortable, even. Obviously, I’ve never been on a nuclear powered aircraft carrier with 180 ft prop shafts, I’m extrapolating from rather smaller scale stuff!
Oh bum. Not had my first coffee yet.
Relatively unlimited in duration perhaps, but limited by the physics of boiling water and the mechanical limitations of steam turbines I would expect.
