Bouba
I thought that was because their cars are more powerfulIts why USA tyres squeal more than UK tyres do ...
Generally ( the squealing is dow to the suspension / tyre relationship. It's been quite a while since I drove a US car on a US road but my impression was that the suspension was very soft allowing the car to roll considerably putting a lot of lateral force on the tyre which in extreme circumstances lead to a loss of adhesion and a squeal.What you put inside the tyre will make little difference ... honestly.
You only have to look at tyres on other gear that often have foam or solid infill .. the outer tyres still crack and deteriorate...
I accept that the compund may be different in the 'rubber' used ... BUT ...
You cannot actually use all USA data in tyres for one simple reason :
USA does not use same formula compound in its tyres as in EU / UK for example. The compound used is determined by the region they are sold in ... nothing to stop you using other regions tyres - but the life etc will be affected.
My Tesla gives me acceleration like I have never known....but it’s never squealed or smoked a tyreI think y'all watching too many movies..all the times I've rented cars in the US of A I've never heard squealing tyres...
The modern tyre of what could be referred to as the major manufacturers is composed of many compounds and different profiles all assembled in the carcass and tread one of which in a tubeless tyre is a Butyl skin / liner that is virtually impermeable to nitrogen and oxygen ( 99%) of the air that is normally compressed to inflate a tyre. so loss of pressure is not a factor except via the seating on the wheel which regardless of molecular size will not be affected by changing from air to nitrogen. There is an argument that could be used for an F1 car in that compressed air could have a degree of water in it and this has different characteristics to a dry gas leading to pressure fluctuations as the tyre warms, it's a very debatable point and certainly not one that would be noticeable in the domestic cars, super, ICE or EV.
The only significant formulation changes are for climatic reasons, hence winter tyres and yes using a winter tyre with its different formulation in the hot summer of Southern Europe or the States will result in reduced life and performance.
There are manufacturers at the bottom of the market that will use less compounds, have less control over their raw materials which will result in lower performance ( life, breaking, road holding etc) Tyres are certainly a product where the maxim "you get what you pay for" is very true but that is not to say that someone that drives a modest car with modest journeys and requirements should be habitually buying "top end" performance tyres more suited to high performance cars.
I thought it was the back wheels that squealEuropean cars front wheel suspension is designed to "lean into" a curve when the steering is turned... US made cars dont all have this feature.... Or so I have been told... And this is what causes the squealing noise.... Discuss - with proof if in disagreement... 50 marks
My Conquistador did.....US made cars dont all have this feature....
Depends how far you need to go on them when you tow. I had a 70 mile trip at the beginning and end of each season The tyres looked fine until one night towing down for a morning launch a sidewall failed totally out of the blue....I have a boat on a yard trailer that gets blocked up. I don't let the tyres down. I'm also Fred down the club who's tyres are now about 15 years old. I do inspect them and they still look fine. Tyre pressure is about 65 psi (400?!?).
About 200m (metres), to the low water line, then wait for the tide to float us off. Trailer probably weighs close to a tonne on its own. 28ft, near 4 tonne boat.Depends how far you need to go on them when you tow. I had a 70 mile trip at the beginning and end of each season The tyres looked fine until one night towing down for a morning launch a sidewall failed totally out of the blue....
I would consider tyres as the primary concern on a trailer being towed at distance and speed. Not in my case however my first trailer tyres must have been 40plus years old originally from a car. I did replace them with high load commercial vehicle tyres. Now 10 years old and done perhaps 100km.Depends how far you need to go on them when you tow. I had a 70 mile trip at the beginning and end of each season The tyres looked fine until one night towing down for a morning launch a sidewall failed totally out of the blue....
I think that might be because a majority of films (movies) involving drammatic tyre (tire) squeals are made in Hollywood.Its why USA tyres squeal more than UK tyres do ...
Possibly.Twaddle
Friend of my Father used to supply all sorts to movies ... from small items up to even aircraft. Its how my Father was in the group that flew the B17's to UK for the movie War Lover.I think that might be because a majority of films (movies) involving drammatic tyre (tire) squeals are made in Hollywood.
There are British "only in the movies" automotive artefacts too. For example, a Ford Grenada with a smoky exhaust appearing in The Avengers is almost certain to drive off the edge of an abandoned quarry, statistically much less common IRL.
