rbcoomer
Can I solicit some views on trims tabs please?
I'm particularly interested in any impact on more efficient cruising in mid-range power (20-30kts) and best possible stability.
I am in the process of gutting and rebuilding an early style 21' Fletcher Arrowbolt - late 70's or early 80's style inboard with cuddy (not later Sports Cruiser type). I'm aiming to get her on the water by early/mid 2013. I have more than enough to be getting on with so not looking for work for the sake of it, but I want the job to be the best I can, so don't want too much retro-fitting.
Is fitting of trims tabs necessary/beneficial on a 21' boat of this style and if so, what would be a sensible product to look at for that won't burn a massive hole in my wallet or be overkill...?
Our 14' handles great, but is quite hard to 'balance' - requiring passengers to move around to avoid her heeling over. The Arrowbolt is obviously a little bigger, but we're more likely to have extra people too. I've also been told that these hulls can have a tendency to 'chine-walk' at high speeds (60kts+)? I'm not really looking to achieve that pace and envisage my setup will probably max-out at around 50-55kts anyway - more than enough for us & my experience level.
I'm perhaps 6 months away from this currently as I'm still replacing floor/stringers, but like to keep a longer-term view on what's needed to enable better planning and steer current decisions. I also find it useful to monitor the market for bargains on my wish-list before I need them!
A good example of this is heating where I intend to install all the ducting etc under the floor, but not actually install the heating yet. The advantage here is that I can pick up a heater as and when a suitable bargain arises budget delaying the overall project. Should I just wait until I can sea-trial her and then review/retro-fit?
There is a degree of modernisation anyway in the rebuild and some 'practical' alterations for more all year UK boating. It's unlikely that the original balance will be maintained as there will inevitably be some extra weight here and there (if that's of significant importance) .
Once finished the boat will be be less speedboat and more of a compact coastal day cruiser. Albeit mostly open (with camper cover) and keeping her classic lines - also quick enough to run for refuge when needed! Whilst the Fletcher hulls have a good reputation for off-shore racing and thus capable of handling the seas, I'm looking for less speed and maximum stability. Ultimately I want to be able to cruise all around the South West (from various launch sites but mostly Torbay) with perhaps a 100 mile range that I can build towards steadily over a few seasons. She has the advantage of being small enough to trailer and sneak into all the best Westcountry inlets, rivers etc, but just about do-able for an occasional overnight/extended voyage...
Notable extra weight items will be anchor/anchor locker (not present currently, auxiliary outboard (somewhere in the 4 to 9 hp range?), extra batteries, heater (& small diesel tank), radar arch and electronics - none of which were previously fitted. If I can figure a means to fit, a chemical loo too!
Thanks in advance as always and apologies for the long waffling post!
