billyfish
Where's yours, up top in the cabin or floor level or in between. My gas alarm is as low as can be but not sure Where's best for CM alarm its sort of head height between main cabin and sleeping cabin.
Oxygen is what we need to breath.Where's yours, up top in the cabin or floor level or in between. My gas alarm is as low as can be but not sure Where's best for CM alarm its sort of head height between main cabin and sleeping cabin.
Air is about 21% O2 (16x2) and 78% N2 (14x2) so an average of about 29 g/mol. CO is 12 plus 16 = 28 g/mol so is very similar to air. The usual advice is to put the sensor at the level you are breathing it at.Oxygen is what we need to breath.
Two atoms weigh 32 units I.e. one molecule of oxygen
CO is 12 plus 18 = 30 units,
DON’T take my word on this - I just used Google - use it as a starting place only.
But the above would lead me to believe air (oxygen) is only slightly heavier than CO so I would place monitor / alarm at head height when sleeping and not down low.
I wonder if any of what I am thinking is correct?
Carbon dioxide will be heavier still.
So head height when sleeping as I suggested would be ok?Air is about 21% O2 (16x2) and 78% N2 (14x2) so an average of about 29 g/mol. CO is 12 plus 16 = 28 g/mol so is very similar to air. The usual advice is to put the sensor at the level you are breathing it at.
Nearby unnoticed boat exhaust may invade a boat through hatches or open ports....As others have said, mid-level or above. Carbon Monoxide is about the same density as air - in fact, its density is identical to that of Nitrogen, and Nitrogen doesn't settle out of the air! However, all sources of carbon monoxide are hot, so the Carbon Monoxide will initially rise and be detectable high up before it reaches lower parts of the cabin; obviously the particular pattern of convection will affect the results in each case.
Mine lives next to the cooker on the work surface, as that's the only source of Carbon Monoxide.
True. The most likely source in that case would be running a generator in the cockpit; the exhaust of another boat is not likely to be close enough. And of course, all our diesel heaters have their exhausts carefully placed to avoid that, don't they?Nearby unnoticed boat exhaust may invade a boat through hatches or open ports....
Absolutely, there have been cases where deaths have resulted in exhaust fumes from other boats. Indeed, there was a recent, tragic, case where two men died as a result of exhaust fumes from their own engine were blown under the cockpit canopy.Nearby unnoticed boat exhaust may invade a boat through hatches or open ports....
This is sll great . Mine is about 10" from the ceiling between the main cabin and sleeping area. So should be perfect
