Forty_Two
So about right thenIt’s more than twice the UK price
They generally stop going wrong, for you, once you sell themWhen do boats stop going wrong ?
It’s nearly midnight and I have noticed a leak coming from the pump assembly at the base of my Jabsco quiet flush electric toilet
I never get to my backlog of jobs because there is ALWAYS a newer more urgent job
The problem is that I haven’t given the wife any incentive to let me get a new oneThey generally stop going wrong, for you, once you sell them
You can’t beat a brexit bog.So about right then![]()
Look on the bright side, only 66 posts start to all fixed is that a record?FIXED IT !!!!!
Seriously, should have been a breeze…lousy eyesight did me in again
Especially if all the jokes were removedLook on the bright side, only 66 posts start to all fixed is that a record?![]()
You sound like a mod , it was a shit thread.Especially if all the jokes were removed![]()
I was just taking the pissYou sound like a mod , it was a shit thread.
I have got 2 , quiet flush , is it worth buying a repair kit ready , ps the secret is turn the stereo up when flushing , the raggie to my right always know ar 3 in the morning when he hears God save the queen by the Pistols . I suppose I should ask him, na he is a raggie , I like it. It’s what I call a Royal Flush.I was just taking the piss
There is an etiquette of not flushing after about 11 pm....you can extend when next to yotties because they don’t stop talking till after 1 am...longer if one of them picks up a guitar. But the truth is if the bowl is so full that I start getting splashes on my legs then I’m flushing (or at least draining the piss which is just as noisy)...and if a motorboat keeps me up all night with their air conditioner pouring a constant stream of water into the sea...then I’m getting up at 4 am just to flush AND wash my handsI have got 2 , quiet flush , is it worth buying a repair kit ready , ps the secret is turn the stereo up when flushing , the raggie to my right always know ar 3 in the morning when he hears God save the queen by the Pistols . I suppose I should ask him, na he is a raggie , I like it. It’s what I call a Royal Flush.
It wouldn’t happen if you got up off your kneesThat’s your problem you see us northerners , are well blessed so if there is any water in the bowl our end gets wet , so we have to flush continually .
I found my problem. My unit had a anti syphon valve in the toilet outlet for holding tanks higher then the toilet / toilet below sealevel. A sort of cross shaped duckbill valve. If anything is too close to the mascerator on start up it takes a couple big slices first before spinning up and becoming efficient and then packs the valve. That rubber valve is much stiffer than those of Sealand Vacuflush and its housing a greater diameter than the outflow pipes so a bit of a collection choke point. I have removed that valve now. Were it neccessary I would probably go with the sealand duckbill being softer and even if it only lasts a year before service instead if 10 its at an easy enough place to reach and service so not too much pain there.Never had that problem in 14 years of Tecma. I always set the water usage potentiometer to maximum water.
Bruce, there is no tp downstream of a Tecma, in the pipe to the tank. One it leaves the Tecma unit, everything is heavily macerated into a blended consistent fluid/slurry and the tp doesn't exist as tp any more.
Bruce, Tecma’s nano version (the one with the small bowl and designed to go on a plinth) is awful. It just doesn’t flush well. Although I think their mainstream unit is excellent and I just specced those for my new boat build, that nano version is always a very poor performer imho.I found my problem. My unit had a anti syphon valve in the toilet outlet for holding tanks higher then the toilet / toilet below sealevel. A sort of cross shaped duckbill valve. If anything is too close to the mascerator on start up it takes a couple big slices first before spinning up and becoming efficient and then packs the valve. That rubber valve is much stiffer than those of Sealand Vacuflush and its housing a greater diameter than the outflow pipes so a bit of a collection choke point. I have removed that valve now. Were it neccessary I would probably go with the sealand duckbill being softer and even if it only lasts a year before service instead if 10 its at an easy enough place to reach and service so not too much pain there.
EDIT mine is the nano version as its on a plynth. Personally I think the problem is down to the mascerator being too close to the business end of the U.
