Toilet seacock 1.5" need to replace
Rhylsailer99
19 Jun 2020
The wood around is rotten and when I unblocked the toilet I discovered the valve does not shut off. I am lifting out next week for 4 weeks so what would be a good replacement thanks.
Pete7
11 Aug 2004
Gosport
OMG, we haven't seen anything like that for a while :eek:
A nice Tru Design 1.5" valve with a matching 90 Deg bend will do once you have a new backing piece glassed in. you will want to change that hose for the proper white sanitation hose if you going to do the job properly. Oh and two clips on the hose please, screws opposite each other.
Search Results for tru design |
Rhylsailer99
19 Jun 2020
Maybe put something like below in the pic be safer thanks
dankilb
23 Jan 2008
+1 for Trudesign. We’re in the process of fitting 6 of them to replace the old (DZR) valves.
I made the backing plates out of epoxy/biaxial sheet I laid up and cut them out with holesaw/carbide grit jigsaw blade.
The DZR varieties just don’t inspire confidence. Not all of the parts appear equally corrosion resistant. The ones I removed were in a very sorry state (after approx 13 years, admittedly). A few disintegrated completely during removal. ?
Spirit (of Glenans)
28 Mar 2017
Me; Nth County Dublin, Boat;Malahide
The valve in the photo is a gate valve, the use of which as a seacock is not considered good practice, so either the DZR type or the composite type of ball valve are what you should be using. If you have space to use the latter you will only have to the job once, rather than every five years or so.
Some attention should be paid to identifying and rectifying the source of the water which caused the backing pad to rot.
john_morris_uk
3 Jul 2002
At sea somewhere.
The Truedesign ones appear to be excellent (I've no experience except when handling them in the chandlers) but they're quite big and chunky. Not a problem if you've got the space, but I'm currently researching seacocks for our daughter's Pandora and the Truedesign ones won't fit into the available space under the bunk where it's got to go.
Plum
6 Jun 2001
UK East Coast
Interesting. That is not my experience of the DZR ball valves from ASAP. I have had at least 15 years service from them without a problem.
www.solocoastalsailing.co.uk
peter gibbs
21 Sep 2016
Theyre all bad to be honest hence why I am lifting out for a few weeks to get them right.
This could be serious - A10 cans to the ready!
The hull apertures must be refashioned to form a firm base- a dab of fibreglass won't do.
Strongly recommend for ease of use, replace taps with ballcock valves
When the new fixing is installed there will be torsion as well as compression and this could damage a newly formed hole in the hull.
PWG
dankilb
23 Jan 2008
The origin of ours was unknown - fitted in previous ownership (but helpfully labelled with the date). The threaded sections of both the valves and the skin fittings had corroded badly, between the valve and the hull.
Used ASAP/Maestrini (or whatever they’re called!) fittings elsewhere and they’ve always seemed decent quality.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Were they definitely DZR, marked as such with CR or (more recently) DZR? AFAIK skin fittings and hose tails in DZR have only been available for a few years.
dankilb
23 Jan 2008
Will check next time. Still got 3 to be removed. I actually assumed anything not bronze (or SS, etc.) was DZR, didn’t know it was a new thing. Couldn’t be straight brass, though, surely wouldn’t have survived any time at all? Corroded areas were pink and crumbly (presumed dezincified!).
Gary Fox
N/A
31 Oct 2020
Tru Design are much bulkier than the ASAP DZR ones, and the choice of fittings to fit your particular boat is smaller; you might not have room for them.
Jamie Dundee
24 Jul 2019
I’m just replacing my inlet with an ASAP skin fitting, ball valve and hose tail. I ordered Trudesign fittings from Leesan but after 5 weeks waiting with no definite deliver date in sight I cancelled and went traditional.
RJJ
14 Aug 2009
That sounds like brass to me
dankilb
23 Jan 2008
Every day’s a school day!
Still rate their TruDesign replacements, mind. I did have a long wait for ours (from Leesan and this was pre-C-19), but worth it for the quality. They also fit perfectly - 42ft AWB so plenty of space for the extra bulk, which I appreciate not everyone has.
