Toe Rails
kgi
29 Apr 2002
andros bahamas
I dont know how they will stand up to rot being made out of beech, mine were made out of mahogany, with a threequarter inch stainless capping strip and they work great, they are also 3 inches thick for the real world of granite docks and old harbour walls, if your boat has a lot of curve in the topsides keep the strips of wood fairly thin 3/8 or so should do it and build the rail up in layers its suprising how much of a compound curve you will have to put in the timber, my rail was screwed and glued to the hull using 5200 and i am extremely pleased with it. ps a big heavy rub rail acts like an external stringer and does reduce flex in the hull.
chippie
21 Aug 2001
Northland New Zealand
Any wood that is of lesser durability can be improved by using a saturating epoxy preservative such as International's everdure. This would work well if you decided to make the toerails by laminating up with smaller pieces as suggested by a previous poster.
International stockists should hold literature on the product.
Good luck
Beech is very porous and not classed as a durable timber - thats why its commonest use is for furniture. Much better material would be iroko or maybe British Colombian Pine /Douglas Fir.
