Daydream believer
Where have you been? have you missed the news lately?Cars don't sink.
When he first posted this thread I doubt that the Op was in the least bit stressed.The artistic among us might say it looks pretty;
Some will say it has yin and yang; and
Others will say that if the failure was caused by stress then by having the clips facing in different directions the stressing will be different.
Those naughty car manufactures only single clipping.Where have you been? have you missed the news lately?![]()
My point is that failures of a single clipped hose joint in far more adverse conditions than a seacock just don't happen. If it did the problem would have been addressed decades ago. The reality is that getting a hose off a seacock after removing either one or two clips is always a pig of a job.Cars don't sink.
Saying that with the depth of some potholes it will happen one day.
EDIT: Is it normal to drive cars about in salt water? Residents of Orkney are excused this question.
I see no reason not to double-clip where the horsetail is long enough to comfortably do so …
I got no problem double clipping hoses on hull valves. There's a certain nice feeling when you are bashing around in high sea states. Even if you don't do that often. It's not like decent quality ones are expensive. Something that does seem to make people dig up excuses over safety. Still, up to them.Of all the jobs on a boat that are doable by a non professional, jubilee clips are probably the easiest....and as someone has already pointed out, if a job is worth doing...it’s worth doing twice
Having changed quite a few hoses over the years, I bless the inventor of the hot air gun. What a bloke.
Wiki. The first patent for a worm-drive hose clamp was granted to Swedish inventor Knut Edwin Bergström [se] in 1896 [1] Bergström founded “Allmänna Brandredskapsaffären E. Bergström & Co.” in 1896 (ABA) to manufacture these worm gear clamps.I thought you were going to say bless the guy who invented the jubilee clip ...because he was Royal Navy
Take a close look at the barb. It is either misshapen or damaged. Smooth it up.The only time I've double clipped is when I'm having problems with one clip not stopping a little seepage.
Two has not stopped it either. Something i will fix soon .Calorifier take off so not critical.
Hose clips can corrode but by then the pipe will have bonded to the spiggot.
You didn't need to know, you can't keep electric in with jubilee c;lips, double clipped or notAnd they only just told me![]()
I am disappointed to see it’s just a flexible screwdriver.....I was hoping it was a real laserWho on earth uses a screwdriver on hose clamps except when it’s easy?
Either one of these: Laser Tools 2162 Hose Clip Driver - 6 & 7mm Heads
or a quarter drive 7mm socket on a ratchet.
And I’ve found jubilee clips rotted and falling off on old boats so I’ve no problem with double clipping below the waterline. They also fit more neatly when one is turned round. The barrel around the screw doesn’t clash with the adjacent clip forcing the clips apart. You can leave a tiny gap that’s even around the circumference to allow the hose to bulge a fraction under compression. You can still have the screws/hex end facing towards you.
The laser is for lining it up.I am disappointed to see it’s just a flexible screwdriver.....I was hoping it was a real laser![]()
