The Bigger the faster.
charles_reed
29 Jun 2001
No contest.
The longer the waterline the faster the boat.
For modern, reasonably slippery boats the displacement maximum is about 1.4 knots X square root LWL FT.
Some displacement boats, given the right conditions will surf at above this speed, at the risk of terminating the crew due to overstimulation.
There is I believe an old saying "In a blow, a big bad'un is better than a small good 'un".
Jeremy_W
23 Jun 2001
Liverpool, UK
The really important point is...
.. if the red wine runs out in Northern Portugal, do not succumb to the blandishments of Vino Verde Red - it spectacularly awful!
On the lesser matter: Yacht speed (assuming similar styled yachts) is a function of the square root of the waterline line. A 40-footer will have about a 25% longer water line than a 32-footer so will probably average just over 10% faster. As with lots of these ratios in sailing, do not bother to calculate with any more precision: It really isn't worth the effort because there are too many variables in the Real World.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
When I owned a GK29 we always used to plan an average 5 knots and never really noticed major inaccuracies. We continued to do the same with the Sadler 34 but realised that our plans were increasingly inaccurate. Last year I calculated our average for the whole season, motoring, waiting for locks and bridges, everything included. Average was almost exactly 6 knots.
RupertW
20 Mar 2002
Greenwich
I picked up this method of calculating from Coarse Cruising where the author estimated 3 knots for his 22 footer and was rarely wrong over a few miles. Once you've done a few trips in a boat then you can navigate pretty well by just looking over the side and estimating the speed as "average", half a knot above/below, or a knot above/below.
Assuming you do the rest of the traditional nav stuff right, then a log is the least necessary instrument for a known boat.
Roberto
20 Jul 2001
Lorient/Paris
sybrancaleone.blogspot.com
I found a very good average on the long run is about equal square root of lwl in feet, not multiplied by any factor.
I found it approximates very well the miserable speed figure which comes out at the end of the passage when you divide direct route miles of the passage by hours sailed. All seems to average out very well: closehauled sailing, running with the sea, motoring if and when, slowing down for bathing, repairs, etc.
pkb
6 Jun 2002
Hampshire
You're friend should definitlely upgrade to a 40 if he wants improved boat performance- but whether or not it should be a Bavaria is altogether another matter.
Peter
