testing twin engines before 500 mile delivery trip.
rigpigpaul
5 Aug 2004
Merseyside & Yalikavak
Hi All, my pal has bought an old twin motor yacht. He plans taking it on a 500 mile delivery trip to its new location. He is concerned about the reliability of the engines. He wants to run the engines at full sea revs for 24 hours to check for leaks and overheating. Is this long enough or should it be shortened. Thanks in anticipation. RPP
Bouba
6 Sep 2016
SoF
Leisure engines aren’t made for full out over long periods of time...check the owners manual....it will probably read some like five minutes at full throttle every hour of cruise for 12 hours every 24...or something along those lines
ChromeDome
25 Sep 2020
If it was me...
Before running the engines like that I'd do all the checks possible + change all filters + oil service.
Then take it out for a run and, when up to normal temperature, allow the engines to run at 75% throttle - for 20-30 minutes in turn.
If temperature and other readings (preferably checked by a wireless thermometer) stay normal, I'd undertake the trip (engine-wise - the rest of the vessel, tools, spares and safety gear of course needs to be checked and up for it as well).
Freebee
21 Oct 2001
Alton, hants
those are very old truck engines 55 year at best ??? ,they were not designed for constant speed but go up and down the rev band , hence 24 hour run at cruising speed is a bit unrealistic. like your friend I would also have some concerns about reliability, they could come through any test OK and still let you down at an important time..... its a big ask. Is there any record of hours run or maintenance and repair???
ChromeDome
25 Sep 2020
We need details.
But.. If they were tractor engines they'd love to go on all day & night at the same rpm, under load.
Trucks, at all times (not least until regulations demanded resting hours) also went on and on. Think about those doing non-stop export runs between distant countries..
Is the 500 miles trip planned to be done in one go?
tillergirl
5 Nov 2002
West Mersea
Sorry, I meant full cruising revs. The engines are 2 x Rootes Lister TS3 MGR.
Wow. Rare engines: a contemporary book describes them as 'two stroke diesel, three horizontal parallel cylinders with two opposed pistons per cylinder. The engine has direct fuel injection, closed circuit cooling and supercharged by blower. Develops 110 BHP at 2000 rpm'.
penfold
25 Aug 2003
On the Clyde
The Chrysler buy-out of Rootes ended it fairly quickly; turbocharging and a TS4 with an extra cylinder were in development when the plug was pulled and the commercial vehicle division went exclusively with 3rd party engines from Perkins etc.
Bouba
6 Sep 2016
SoF
These engines are not powerful in today’s sense...so they may not need to go flat out nor even cruise...just get to hull speed at just over tick over is maybe all you need....it might be a long journey
Portofino
10 Apr 2011
Boat- Western Med
Too many variables here to pin it .
Just go with your gut feeling and check out the life raft and ERIB , perhaps plot a course hugging the coast and nip and buy some new extra flares .Then go for it .
Get it insured , goes without saying .
Try not to bond with it early …..wait to see if it makes it .
The Orca quip ^ on reflection would be my biggest worry = you go into the LR .= orcas eats LR and contents .
penfold
25 Aug 2003
On the Clyde
A hour at good load would satisfy me of engines but fuel quality would be a bigger worry if it's been sat around, clean oil fuel and will keep an old diesel running fine but a filter full of sludge will stop it dead, and you won't find out till it gets rough at sea.
That's good advice; at least have a supply of spare fuel filters, disposable gloves and tools for changing them(and stugeron for the lucky winner), but preferably inspection of the tanks to check for debris/bug growth etc and clean if they're full of gunk.
kashurst
10 Oct 2003
Spain
Sorry to be thick, but isn't this just a case of following the coast?
Essentially yes, but there are some long stretches with no harbours or protection.
I would do a few local runs around the area first. Down to the Mar Menor and back. Lots of harbours on that leg if something starts playing up. If everything is OK after that, the engines are basically OK. Thereafter reliability on a long run needs two things - good cooling and clean fuel.
What you need to watch out for is cooling system failure on a long run - so take spare impellers and/or belts. Some self amalgamating tape, and a selection of jubilee clips. I used to take an infra red thermometer with me and point at the engine at key points to keep an eye on things.
And fuel supply.
Does the boat have racor filters with clear bowls. After all those years there is bound to be carp/water in the tanks that will start to move around. If the boat does not have such filters I would definitely change them to Racors and take a big box of spare filters. Then practice changing them. Then you can keep an eye on things as you travel.
Tranona
10 Nov 2007
Don't forget the earplugs! Hopefully the boat has an autopilot so you can sit on the foredeck well away from those screaming monsters!
