vas
Re: port gearbox works only on reverse
comeon then, give us the top 10 WD videos!
I'm worried that the heat and sun down here will destroy this tape. Was even thinking of getting small rods (circa 3mm) welded on the back of the letters and drilling one hole on the transom for each letter, AND use the 3mm VHB tape
fingers crossed it's this P.
Theory matches with the worn out sections of the diverter valve body which is just where the oil seals should have been. Problem is that I've not seen ANY traces of rubber/silicon or whatever in the box/oil. May have disintegrated completely and wasted in the oil...
Still my problem is what type of o-ring do I get, yes, I know I'll get a few different sizes and try them out and remove the assembly on 10h to check condition.
I'll try silicon as they handle heat much better and it's what was used originally on the gbox oil heat exchanger. I don't like the fact that the o-ring will have to seal 300psi between a rotating axle and a casing.
Another point (just thought of it!) is that the reverse axle has exactly the same setup and also doesn't have o-rings! OK, body is not worn, which implies that with the right tolerances system works without o-rings.
Wonder if adding rings may cause any problems (overheating or something like that) compromising the strength of the axle. Similar to what happens with wrongly adjusted stuffing box that can overheat and destroy the axle.
cheers
V.
You're talking to an expert here on wasting time watching Wheeler Dealers. Of the 100 made, there's probably about 10 stand out ones if you want to be more selective!
Cool, let me know about the socks, no rush.
Regarding the letters, get some narrow 3m VHB tape (eBay) and get the wife or kids to cut it into pieces and stick it on. Note that the tape comes in various thicknesses that you might be able to use if you have a slight curve where you're fitting the letters. Pics would be great!
Vas, hopefully you have found the culprit, and it passes the test of reasonableness as well, as to why it was OK when first re-launched, and then suddenly failed. I guess the seals may have deteriorated after several years being idle, and you have found some of them in the debris.
cheers
V.
